[SOLVED] CP boot issues need help!
Jun 18, 2020
Hello everyone,
since 2 weeks ago I have been having an issue with my computer every time I power it on I get this screen:
"Please enter setup to recover BIOS setting"
"when RAID configuration was built, ensure to set SATA configuration to RAID mode.
"Press F1 to run SETUP"
Other times I get the screen "Boot device not found please press any key to continue" and by simply restarting the computer and going into the bios and selecting the boot drive it fix still kind of clueless why this is happening any help you can provide me?
Thanks in advance!
D
1. First of all right click on Start Menu and go to Control Panel.
2. Go to System and Security. Click on System. Now click on Advanced System Settings.
3. Go to Advanced tab. Tap on Settings under Startup and Recovery.
4. Under Default Operating System, you will find the dropdown box for choosing the default operating system. Choose the OS and save.
If this does not help, I would consider the possibility of a hardware problem to the raid controller.
