So today for the first time I got a blue screen of death and after powering off the pc and trying to start it up again it wouldn't saying "CPU overheating". I got my pc 3-4 years ago.
So I let it calm down, power it on, and run HWMonitor. Behold, all cores on my i5 3570 at 100 degrees CELSIUS (not Fahrenheit) without doing anything at all. Like, is the pc even supposed to be able to run at these temps? I shut it down quickly just in case. Note that I also took off the pc cover while it was running and put my hand near different parts to see if I was noticing any heat. I couldn't feel any heat but maybe it's because the room temperature was only 18C. I mean, if it was just a faulty cpu temp sensor why would my CPU be struggling at idle.
I looked it up and the most common causes are improperly seated heat sink or thermal paste needing replacement. I took the fan offf to check the thermal paste but I've never done this before and I'm a complete noob so I don't know what's supposed to look right and what looks wrong. Here are the pictures:
Heatsink paste: https://s17.postimg.org/jnsjgj0y7/heatsink_paste.jpg
CPU paste: https://s16.postimg.org/k0nxinst1/cpu_paste.jpg
So based on your experience do you think these look bad enough to make a CPU run at stable 100C at idle state and even give blue screen of death? Or is it something else? Power supply over/undervoltage? (the fan works completely fine btw and there's no dust in the pc or the fan). The funny thing is I took my pc to a technician like 3-4 months ago for the same issue but on my graphics card. Blue screen of death from GPU overheat. Turns out it was the thermal paste. Is this the famous "planned obsolescence"? Or is it just that all thermal pastes need replacement eventually? (I got the pc 3-4 years ago off of ebay and never had any issues other than the GPU thermal paste needing replacement and the issue I'm having now with the CPU)
I hope the thermal paste is the issue and not some harder to spot problem like power supply over/undervoltage or some shit...
Thanks in advance a ton for any help. Really appreciate it.
