CPU AIR Cooler For i7 7700K
HSCSGO
206
I want to get a better CPU air cooler for my i7 7700k, which one should i buy? max 75$, i was thinking about the Dark Rock Pro 4
NZXT H500
Also very good coolers, and I'd throw the Noctua NH-D15s in to the mix as well. It's only a couple degrees off of what the NH-D15 cools at, is $10 cheaper, and wont have any RAM clearance issues that the NH-D15, NH-D14 and Dark Rock Pro 4 have.
But for the extra $10, you get another NF-A15 140mm PWM fan. That fan can be used elsewhere in the case, and you still have the NH-D15S version with one fan.
That NF-A15 140mm PWM fan is $22.
There is also a tiny bit of difference in the cooler design, but nothing really noticeable if the motherboard was already compatible with the NH-D15. If the OP has a use for the extra fan elsewhere then by all means the NH-D15 is a better deal as Noctua fans tend to be pricey.
