Question CPU Air cooler for Ryzen(AM4)? where are they?
askara
246
Planning to get 3700X, so i was just looking around for decent cpu cooler. but surprisingly, majority of CPU cooler either doesn't support AM4 or AM4 bracket is sold seperately which are out of stock everywhere.
I was planning to spend about £40 but below £50 ish. i found quite a few bargain deals digging around that is selling almost £20 below amazon price but sadly they all not AM4 compatible. any recommendation?
Weird, Cryorig Quad Lumi sells with Am4 bracket as the Dark Rock pro 4 and every other cooler...?
I would ask seller tho.
On their site it states am4 support..
http://www.cryorig.com/h7.php
But there are plenty of other coolers, as Dark Rock Pro 4 is good.
the Cryorig Quad Lumi is the newer version so it comes with AM4, the normal H7 definitely doesnt. the AM4 support page must refer to the AM4 bracket add on. unless they started bundling with the new batch but i doubt it. Dark Rock pro 4 is outside my budget. may pick up the dark rock 4 even though its bit more expensive than i would have liked
shame the ryzen cooler is so limited compare to intel. all the cooler with great deal is up to Am3+ only
The Ryzen coolers are probably some of the best stock coolers out there and can compete with $20-ish aftermarket coolers. Try the stock first and if it doesn't suit your needs then buy a aftermarket cooler.
Yeah, its seems to be almost on part with hyper 212, but its too loud. fan noise which is my number one pet peeve
