D DeucalionZ Reputable Jun 22, 2014 28 0 4,530 Aug 16, 2014 #1 My cpu fan and case fan and psu starts for a brief second but the system doesn't boot up Is something faulty on my end? Did I connect the cords right ?
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,807 1,861 159,590 Aug 16, 2014 #2 Specs? Upvote 0 Downvote
D DeucalionZ Reputable Jun 22, 2014 28 0 4,530 Aug 17, 2014 #3 Amd fx-6300 Amd 7750 ddr5 8 gig of ram ddr3 (1060) 500 gb hdd And mother board is an m5a78l-m Upvote 0 Downvote
A AndyPC Reputable Aug 17, 2014 3 0 4,510 Aug 17, 2014 #4 Did you connect the additional 4-pin power connector to the motherboard? Upvote 0 Downvote
D DeucalionZ Reputable Jun 22, 2014 28 0 4,530 Aug 17, 2014 #5 My 4p is with my eatxpwr cord which on the mother board it Has an 4pin combined with it. And I have a cord labeled cpu with a 4 pin connector and I plugged it in the atx12v Upvote 0 Downvote
J Justin95 Honorable Jun 24, 2013 13 0 10,510 Aug 20, 2014 #6 I have the same problem. I tried all the CPU power pin combinations; none of them helped. Heres my thread: http://www.tomshardware.com/answers/id-2268512/loose-cpu-socket-stopping-post.html i think it may have something to do with the socket itself. Upvote 0 Downvote
