Hello
I have been researching parts for a new smaller build for a friend and have found a motherboard and CPU that seem to fit the job nicely. However, I'm not completely sure if they will be compatible out of the box or whether a BIOS update will be necessary
Motherboard:
http://
CPU:
http://
Will this pairing be able to run as they are out of the box or is a bios update essential?
If a bios update is needed, will i have to use a second different CPU to perform the update?
Thank you
Motherboard:
http://
CPU:
http://
Thank you
