Question CPU and DRAM debug led after changing processor
Feb 9, 2021
5
so.. after updating bios 7B00v1JR beta and changing cpu (ryzen 3 1200 to ryzen 5 2600) my pc cannot boot, debug led cpu and dram lit up.
before changing the cpu (update latest bios) there is no trouble at all
for now, i don't have other compatible parts
how to fix it? thanks
spec
  • ryzen 5 2600
  • msi b350 gaming pro carbon
  • galil evo x 2X4gb
  • saphhire rx580
Version 1JR is meant for a Ryzen 3000 CPU but it should work for a 2000. Did the update go as expected?
Try resetting CMOS: turn off and disconnect power cord, remove the coin cell battery and short the pins for a minute or two. Reassemble and try it.
Feb 9, 2021
5
willco 👍
edit: tried clear cmos? not solving the issue
sorry to hear that...
But when you did it, did the BIOS update go as expected? meaning it progressed through and then restarted the computer...or told you it was time to restart.
When you try to start it with the 2600 are you getting both the CPU and DRAM debug LED's lighting steady? You might try one stick of DRAM at a time just to see if something's amiss there.
Feb 9, 2021
5
Found the problem, faulty ram. Pretty sure about it.
Thanks for your assist dude
Reactions: drea.drechsler
