whenever i turn the computer on the CPU and DRAM led's turn on for a second, aswell as all of the fans. but then everything turns off and then the system just endlessly repeats this.
this is my first build so i may be missing something really obvious.
however im pretty sure the processor is seated well onto the pins.
The 8-pin CPU power cable is connected
im also pretty sure it is an issue with the CPU aswell, as when i remove the processor power everything else then boots (obviously not the CPU)
Components:
ASUS P8P767-PRO Motherboard
Intel Core i5-3570 3.40GHz (Ivybridge) Socket LGA1155
EVGA GeForce GTX 650Ti BOOST SC 2048MB GDDR5
Silverstone Strider Plus 1000W Modular '80 Plus Silver' Power Supply
Corsair Vengeance 16GB (2x8GB) DDR3 PC3-12800C10 1600Mhz
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache
BitFenix Merc Alpha Gaming Case
OcUK 24x DVD±RW SATA ReWriter
Thanks for any suggestions on what the problem is or how to make it work
Components:
