[SOLVED] Cpu and Dram Led Lit on Asrock b550 phantom gaming 4
I have a
Ryzen 5 5600g
Asrock Phantom Gaming 4 B550
Rx 6500 xt
16gb 3200 2x8 G.skill
Crucial 500 gb m.2
600 Evga psu
Fractal Design Case
When i go to turn on my pc the cpu and dram leds light up and i get no video signal to my monitor. I had my bios updated to 2.10 - which is the latest one from asrock - using a ryzen 3600. After the update using the 3600, my mobo, and ram my pc would boot to bios every single time. Now when my 5600g would be put back nothing would happen. No post and cpu and dram lit up. I have tried a b450 and a b570 using my cpu and ram and it would post with both of those two motherboards. I have tried sticking one stick of ram into every slot by itself and clearing cmos after every try and still nothing. Customer support told me the motherboard doesnt work and must be replaced. Im hoping that somebody has had a similar problem like this and has solved it. Any help is appreciated thanks.
I have a
Ryzen 5 5600g
Rx 6500 xt
Crucial 500 gb m.2
600 Evga psu
Fractal Design Case
When i go to turn on my pc the cpu and dram leds light up and i get no video signal to my monitor. I had my bios updated to 2.10 - which is the latest one from asrock - using a ryzen 3600. After the update using the 3600, my mobo, and ram my pc would boot to bios every single time. Now when my 5600g would be put back nothing would happen. No post and cpu and dram lit up. I have tried a b450 and a b570 using my cpu and ram and it would post with both of those two motherboards. I have tried sticking one stick of ram into every slot by itself and clearing cmos after every try and still nothing...
I have a
Ryzen 5 5600g
Rx 6500 xt
Crucial 500 gb m.2
600 Evga psu
Fractal Design Case
so with 5600g on that mobo, it just wont post, but did you tested it again with the 3600 after putting the 5600g?
i was thinking to flash older bios such as 1.80 using the 3600, then use the 5600g, and update it straight to 2.10.
