Ryzen 5 3600 (Default Turbo Clock)
Aorus x470 Ultra Gaming
2x8gb DDR4 HyperX Predator 3200mhz
Asus ROG Gtx 1060 6 Gb
Cooler Master 600w
FSP 520 case
So basically ive had this build for a while, everything worked perfectly, no issues at all. As someone who uses his pc a lot (avg 6-8 hours) (mostly gaming)
There were no issues until today. Well i used my pc for 1 hour and decided to turn it off. Had some job and then came back to play games after 5 hours turned on pc but it didnt give any signal on monitor. After some time of looking at cables to check if everything was pluged in, i realized that the RGB Aorus logo isnt shining, also no lights from keyboard and mouse (RGB), and on Ez Debug the CPU light was on for like 5 seconds and then DRAM kicked in and was on for the same amount of time and it looped like that.
So as everyone else i hoped i will find a solution on internet, checked many related threads and tried these things:
-Removing 1 RAM stick and trying to run it, also tried all slots
-Checked all the cables to make sure something wasnt plugged in
-Took out the CMOS for like half an hour, changed the one i had with the other one
-Removed the CPU fan and checked the pins on the CPU they all looked straight
I bought this motherboard in 01. August 2018. And PSU that is a bit older than motherboard. Im thinking that one of these are faulty. Im just scared that it didnt damage CPU or GPU. So if anyone have any recommendation i will be really thankful.
Cooler Master 600w
FSP 520 case
