Question CPU and DRAM MOBO lights on and can't connect to monitor
Aug 24, 2019
Hi folks, finished my first build using the following:
CPU: Ryzen 2600x
MOBO: MSI Bazooka V2 B450
Gcard: Zotac Geforce 1660
Ram: 1x8gb 3200 Ballistix sport (x2)
PSU: EVGA Gold 650
Case: Thermaltake H17 Versa Micro-ATX
I have been losing my mind because when I start it I can't connect it to my monitor, but it appears to run (CPU, GPU, case fans all run). When I boot it starts the DRAM and MOBO lights come on the motherboard. I've tried about every trouble shooting possible - reconnect/connect all cables, tested MOBO outside case. reset CMOS by pulling the battery, nothing has worked and I'm flat stumped.
Aug 24, 2019
Yeah I've checked the RAM a lot and done 1 stick as well, still without success... Debating at this point if I should just try to return the MOBO and CPU :(
