Hello, I am running a Intel 2500k@ 3.3Ghz with 8GB DDR3@1666Mhz; ENGTX 260 SLi.
All boxed inside the Antec Lanboy with the standard 5x 120(I think)mm fans blowing inwards. I have the standard CPU cooler on.
lately when I'm playing games my CPU warning will pop up saying warning CPU temp. reaching 70C+, and when I check my GPU's one will go up as high as 78Deg Celc and the other one on the outerside will be normal +-50Deg celc.
Now I have cleaned the box out and still the same problem, I don't overclock, coz I don't know how but I also don't need it!
I was thinking on getting the Antec Kuhler 920 Liquid Cooling System but then I read liquid cooling is not really needed if you don't overclock!? so I thought maybe just getting a nice air cooler wich wont be too expensive but will work great. Also, what can I do to cool down the inner GFX card? It is obviously sucking the heat from the 2nd gfx card in to cool itself down.
Will it help if I direct 2 of the 5 fans to blow air out? But then again the box is open enough for air to flow through.
Thank you in advance
Wessie723
Wessie723
