Question CPU and GPU and Motherboard Overheating After my recent upgrade
May 18, 2019
20
I had my old system :-
i7 4790k
motherboard :- Msi z97 A gaming 7
GTX 960 2 gb
8gb ddr3 heat sink ram.
700W circle power supply
128gb ssd
1tb hdd.
Dell 60hz Monitor
My recent uprade in it.
i added 8 gb of ram extra yesterday
and installed RTX 2060 MSI XS Ventus.
I am getting good gaming performance, but my motherboard gpu and processor is heating alot. as shown in the image.
Please suggest me what to do with this?
May 18, 2019
13
Are you getting more frames after the Ram upgrade?
If so, it could be that your CPU and GPU can now send more data back and forth, thus the temp increase.
Other than that, I'd suggest you to check if the fans are clean or not.
Also, Change the Thermal grease on both the CPU and GPU.
May 18, 2019
20
I dont have any liquid cooler or any thermal paste , etc applied to my processor. its just a normal single fan which came with my cabinet.
If I'm not mistaken, from the images which you have posted, the GPU TEMP value is 73 C, and CPU sits around 83 C max. I don't think this is overheating, at least for the GPU. It's normal for the temp to hover around these values, when under full load/stress.
But you should definitely grab some Liquid Cooling solution for the CPU, if possible. The Stock cooler isn't that good, which comes with the processor. Also, on a different note, please change your current power supply unit as well. The "700W circle" PSU is of very inferior/poor quality, and this is not a trusted PSU brand either. Don't take risk using this power supply unit.
I think that's a local INDIAN branded PSU, IMO. https://www.uniqinfotechindia.com/circle-raw-power-700-watt-apfc-atx-version-2-31-modular-gaming-power-supply-smps.html
20
So will adding a good liquid cooler solve my problem? and also getting sudden drop in frame rates, like while playing the frate rate drops from 150 to 85 suddenly, and you feel a sudden lag for 2 seconds. Why is that?
Satan-IR
1,450
168
11,890
164
Yes, as mentioned, that's a Haswell refresh CPU, known for higher temps. Are overclocking by any chance?
That is not a good PSU. Replace that. Frame rate drops can be because of throttling due to heat or insufficient clean DC from PSU to the card.
Noctua's are great. Get one if you want a good air cooler.
Reactions: Metal Messiah.
May 18, 2019
20
i installed a coolermaster liquid cooler ML240L, now my processor is not heating up, and motherboard is also good. only the problem is GPU, while playing pubg ultra , fps 165, temperature raises to 80 degrees, that games uses 97% of my graphic card.
Okay, thanks for the update. Like I mentioned above, try to use some other high quality PSU to check the GPU as well on your PC. If you can't BUY a new one, try to borrow one from your friend, if possible. But I would still highly suggest you to stop using your curent PSU model from CIRCLE.
80C is not a very alarming TEMP value when the GPU is under heavy load.
Satan-IR
1,450
168
11,890
164
That's good. That GPU getting to 80C under such load is normal I'd say.
This depends on the ventilation inside the case and to a lesser extent on ambient temps. Having better ventilation inside the case would help a bit and water coolers don't help decrease the temps inside the case and over VRMs and such as opposed to air coolers when the air is going out the back and top.
And get rid of that PSU like it's the plague.
