CPU and GPU Temperature question..
Dec 25, 2018
27
Hello, i want to ask on the readings of various software(Coretemp, MSI Afterburner,HWMonitor) to measure temps of my pc:
CPU and GPU temperature on indle: 38 degrees celsius/ 38 degrees celsius respectively
CPU and GPU temperature under load (gaming on max settings 1080p): 60-65 degrees celsius/ 60 degrees celsius respectively
Sometimes, CPU temps under load spike at 70-75. Though this happens only sometimes, I'm worried if this can shorten the life span of my CPU (i7-8700) Plus, i live in a place with a hot climate. (Room temps 30 degrees celsius and above)
Am i still in the "safe" range of temperature ? Thanks!
Thanks mate! I was worried. Don't want the CPU dead before Cyberpunk 2077 or ES6 releases.
CPU:i7-8700
Motherboard: Aorus h370 gaming 3
Ram:T-force Delta 2x 8G 2666 MHz
SSD/HDD: Gigabyte 240G / Seagate Barracuda 1 TB
GPU: Gigabyte GTX 1080 WIndforce OC
PSU: Thermaltake Toughpower 750W
Chassis: Tecware Vision with 6 intake fans (3 front, 3 on top of PSU shroud) and 1 exhaust (all 120mm)
