CPU and GPU temps
SidTheSloth
269
i am using the stock fans, and the same fans that came with my case (200r). I get around 60 degrees max, and around 50-55 avg on my CPU, and 72 degrees max, and around 62-3 degrees avg on my GPU. Are these temperatures dangerous? (My cable management is very poor, I am using a traditional PSU)
Download HWMonitor and run it to check temperatures, then run Prime95 for 15-20 minutes. What CPU are you using, as long as it doesn't reach over 65C, it will be OK. Shut off Prime95 and download, then run MSi Kombustor for 15-20 minutes. If the GPU temperature doesn't reach over 80C, it is also normal.
