Question CPU and GPU usage below 70%, help
Chipster339
16
I am experiencing in most games a low utilization of both GPU and CPU, with cpu almost never going up of 80% and GPU being lower than 65%. I think I am missing a lot of fps in games, for example on bf5 all on ultra I have around 90-110 fps with utilizations mentioned above. I know I should have more also because people in chat told me it's weird. If it's any help, when i raised scale resolution to 200% on bf5 the fps dropped to 50-60, CPU utilization went down to 40-50% and gpu to 75% max. I don't know where my bottleneck is. I tried both on ssd and hdd. Frames are the same so the problem is not there.
Here are my specs. I also a score of FurMark which I do not know if it is ok.
I already know about power management for the cpu. And also on nvidia panel I already changed all I could to max performance. I also tried both with overclocked CPU and default CPU, frames do not change as far as I can tell.
Power supply: CORSAIR RMX White Series (2018), RM750x, 750 Watt, 80+ Gold Certified, Fully Modular Power Supply - White
RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz C16 Desktop Memory Kit - Black (CMK16GX4M2B3200C16)
HDD: Seagate FireCuda Gaming 2TB Solid State Hybrid Drive Performance SSHD – 2.5 Inch SATA 6GB/s Flash Accelerated
SSD: Samsung 970 EVO SSD 500GB - M.2 NVMe Interface Internal Solid State Drive with V-NAND Technology (MZ-V7E500BW)
Motherboard: Asus ROG Strix Z390-E Gaming Motherboard LGA1151 (Intel 8th 9th Gen) ATX DDR4 DP HDMI M.2 USB 3.1 Gen2 802.11AC Wi-Fi
Cooler(CPU): ARCTIC Freezer 34 eSports DUO - Tower CPU Air Cooler with BioniX P-Series Case Fan in Push-Pull, 120 mm PWM Processor Fan for Intel and AMD Socket for CPUs up to 210 Watt TDP - Green
Case: Rosewill Gaming ATX Full Tower Computer Case Cases Thor V2 Black
GPU: GIGABYTE GeForce RTX 2070 Super GAMING OC 3X 8G Graphics Card, 3 x WINDFORCE Fans, 8GB 256-Bit GDDR6, GV-N207SGAMING OC-8GD Video Card
CPU: Intel - Core i7-9700K Octa-Core 3.6 GHz Desktop Processor
Monitor: AOC C24G1 24" Curved Frameless Gaming Monitor, FHD 1080p, 1500R VA panel, 1ms 144Hz, FreeSync, Height adjustable, VESA
View: https://imgur.com/a/oZih2EB
