Cpu and motherboard compatibility
stevenboughton13
I am looking to buy a asus 970 pro gaming motherboard and a fx 8350 from pc part picker but it is saying there is a compatibility issue and that I need to update the bios with a compatible cpu first.
My question is can I not just update the bios with the fx 8350 in the motherboard and it work or what cpu can I use to update it without spending a load more money?
My only other solution is buying a 990x motherboard but I'm struggling to find anywhere that sells them for a reasonable price.
Thanks for your help
