I just finished my build last night and while monitoring the cpu I noticed it creeping up through the 60s on idle! It rising and rising. I figured I seated the cooler wrong and figured I'd fix it after work the next day.
So I turn it on today and now it's idling at 26, I let it run for about half an hour and only got a temperature change of a few degrees, to 30. I over clocked it as well and still hovering around there.
You guys think it's ok? Cause I don't wanna start doing cable management only to have to pull out the mobo.
Asus max gene
8 gb ddr3 @ 2000.
I5 4670k
Zalman reserator 3
Asus max gene
8 gb ddr3 @ 2000.
I5 4670k
Zalman reserator 3
