CPU bracket/mount won't stay on
Further shore
18
Hello. I was attempting to clean my computer and reapply some thermal paste when I unscrewed the bracket and did what I needed to do. Unfortunately once I was finished reapplying the thermal paste the screws on the bracket would not screw back in. I tried applying some pressure and continually screwing but it just seems the screws are too short now for some reason. I feel like there is a simple solution to this but so far it had been very frustrating. I'm not quite sure what I did incorrectly. Again, it unscrewed fine but trying to screw it back in just isn't working.
There is a pattern behind the board, you must place the bracket in the exact place without overlapping any screw behind the cpu socket
I wish I could show you photos but everything is lined up correctly from what I can see. The screws just won't go down to where it needs to be. Literally the only thing I've done differently than other times I've cleaned my computer was take off the bracket.
