Question CPU clock ratio/mode and cpu vcore ?
Have you tried using Curve Optimizer within Ryzen Master? What are you using to cool your processor?
alright to update to your question, things ive done so far:
  1. expo 1 enabled
  2. pbo advance
  3. pbo limits to manual: ppt limit to 85w or 85000mW
  4. platform thermal throttle ctrl to manual and thermal throttle limit to 85
  5. curve optimizer all cores, negative, 30
i have not used ryzen master since its windows software only prefer using the good ol bios for these kind of stuff unless you completely suggest me to do so.
about thermals ill show you two screens that i took after having run a test with cinebench23
View: https://imgur.com/a/LpFpIJk
View: https://imgur.com/a/7w8e7tU
  1. expo 1 enabled
  2. pbo advance
There should be CO settings in BIOS too, it's best way to keep voltages in check as they are corrected automatically.
