Hi everyone.
Soo I'm having a weird HWMonitor reading lately that shows my CPU core clocks drop from 4.3Ghz to below 100mhz lowest I've seen was 58Mhz among other crazy low clock speeds.
What gets me is I'm gaming and never experience any fps drop that would suggest a drop in clock speed due to heat or downclocking.
On another note what really bugs me is the core voltage that drops to match usually sitting at around 1.332/1.320 it drops respectively to 0.980 I'm completely puzzled I mean I would definitely see fps drops with that happening unless it's doing it 1 core at a time perhaps?!
Specs
AMD FX-6300 OC 4.3Ghz at 1.332v
Motherboard Asus M5A97 R2.0
PSU Huntkey 750w
Gpu GTX 1060 6GB (I know poor Cpu)
Other oc settings
Cpu/NB 2200 stock voltage
HT 2400 stock voltage
LLC off both Cpu and NB
Cool & Quiet Enabled
C1e Enabled
C6 Enabled
HPC Enabled (Should this be on?)
Temps I usually get are
Cpu 47/52
Package 48/50
Motherboard 32 (HWMonitor)
Gpu 64
Specs
PSU Huntkey 750w
Other oc settings
C1e Enabled
C6 Enabled
Cpu 47/52
Package 48/50
Gpu 64
