CPU clock speed fluctuating ?
sandydudeman
37
i7 6800k with water cooling
the clock speed in Cam software and also in CPUZ is fluctuating between 1199 to 3397MHZ when IDLE !
temps are normal
load is normal
why is the clock speed fluctuating ?
DOES this has something to do with Intel speed technology ?
The clock speed will fluctuate based on load. At idle it will run much lower clock speed and voltage to save on power and temperatures. Under load it will go to advertised speeds or a little faster due to Turbo Boost. High performance option in Windows helps a lot with this.
but even at idle ? i mean isnt the clock speed TOO high for background processes ? (1199 to 3000mhz ? ) is this kind of clock speed normal ?
Absolutely, positively, completely normal.
