Question CPU clock speed low while gaming
May 13, 2019
23
I have been having a problem with major gaming underperformance. While my pc is idle my CPU clock speed is around 4 Ghz. However, when I start up a game it dips to 1.9Ghz and almost never goes above 2Ghz this is causing me to have around 30 fps lower than I should get.
SPECS:
Ryzen 5 2600x
Aorus RTX 2070 8GB
Asus ROG Strix B450 F-Gaming mobo
2x8 corsair vengeance rgb pro at 3000Mhz
and a corsair cx750 PSU
I should mention I do monitor temps and my CPU never gets above 55 and my GPU is usually around 65. thank you in advance to anyone who helps.
DMAN999
696
166
590
Have you tried changing the power plan you are using back to default settings or even changing to Ryzen Balanced plan?
My Ryzen 5 2600 idles around 1.55 GHz and clocks up to 3.95 Ghz under load.
May 13, 2019
23
Try setting it to high performance mode, it could be holding down the power for the cpu, have you monitored the power it is consuming?
I did have it on that. I do not have software to monitor voltages and stuff. What one should I download. I can’t get MSI afterburner to Work
Javi7707
Commendable
Feb 20, 2017
61
4
1,545
Core temp will tell you how much the cpu is consuming and its junction temp, download it and run a game to see if it is consuming what it should, it's tdp is rated 95w so let's see if it gets stuck at some point, just pay attention at the consumption when the frequency drops
May 13, 2019
23
I will later today. The frequency drops as soon as I start a game.
May 13, 2019
23
If core is new, maybe you should change it. Still you can look the temperature and change settings to default. How high is the fps? Lower then 30?
FPS is still decent, but I’m getting about 30 less than what I should be. For example I should be able to play BFV in ultra settings at ~110 FPS but I’m only getting ~95 on high settings
