Question CPU coolant temperature issue on prebuilt PC ?
tlavanway3
237
PC model: Corsair One i165 Compact Gaming PC
When I adjust the RGB lights that are on the Case of my Corsair one i165, it changes the Tempture reading of my AIO coolant for my CPU. When I have the brightness set to 0 my CPU coolant drops to 40c but when i max out the brightness my Coolant tempature spikes up to 60c which in turns causes red lights to flash on my case.
Hello,
Adjusting the RGB lights on your Corsair One i165 affects your CPU coolant temperature, dropping to 40°C at low brightness and spiking to 60°C at high ADPVantage brightness. This may be due to power draw issues. Ensure your power supply is adequate, update firmware and iCUE software, check the cooling system, and try different RGB settings.
Most like a code problem with the firmware. Contact Corsair technical support and report the problem to them
There are free third party applications that can check the CPU temp so you can monitor it at idle and when doing gaming.
