CPU Cooler and System Overall
Dalef11
62
Hey guys,
Here is my current rig:
A6-5400k Processor with integrated AMD Radeon HD 7540D
F2A55M-DS2 Motherboard
HD 6670 Graphics Card (override the use of 7540D)
500w PSU
8gb Ram
1terrobyte HDD.
Templar Case (Micro ATX form factor)
I AM GOING TO BE UPGRADING THIS TO:
Intel i5 - 3570k
ASRock Extreme 4 m-ATX motherboard
AMD radeon graphics card (high end) haven't decided yet.
600W Corsair Builder
8gb ram,
1terrobyte HDD,
Templar Case (Micro Atx Form Factor).
Now, my question is, I need a CPU cooler for the i5 - 3570k as I will be overclocking it. As my case is a Templar Case in a Micro ATX form factor, what cpu cooler will fit? Here is the dimensions of the case:
183mm x 365mm x 430mm
Of course, my new upgraded motherboard will also be micro atx. I need a decent CPU cooler, i am willing to pay around £50 - £100 as it is rather important for the i5 - 3570k overclocking.
Thanks, Dalef11.
Well, my first question will be, do you plan on overclocking? If no, then don't get the 3570k and just get a 3470 which can be used with stock cooler. If you plan on overclocking, than as you pointed out, the normal recommendation, Hyper 212, might not fit in the case. Take a look at the CM GeminII.
