Hello, I am looking for a CPU cooler for this build.
Here is my case:
http://www.aerocool.us/pgs/pgs-b/x1_black.htm
Dimensions are:
Chassis Dimensions 482mm (H) x 190mm (W) x 475mm (D)
Carton Dimension 537mm (H) x 249mm (W) x 540mm (D)
And it mentions the max cpu cooler height as 158mm.
And I need a CPU Cooler that will fit in here for the i5 6600k (keep in mind I may overclock).
I don't mind if it is air or water cooled.
Finally, a quick question is whether the Cooler Master Seidon CPU 120V R2 will fit in the case?
Thankss
Here is my case:
Dimensions are:
Thankss
