CPU Cooler Case Compatibility
JeremyStone22
30
Is the NZXT Kraken x62 compatible with the Phanteks Enthoo Pro M Tempered Glass Case. If possible i would like to mount it at the front towards the bottom and mount the other included fan on top of the rad. Thanks in advance.
The x62 is compatible with the Enthoo Pro M TG Case. There's a completed build on pcpartpicker you can peruse if you wish, using the specified case & cooler, though in this build it appears the x62 was placed at the top of the case. According to the case manual on Phantek's site, the x62 is well within the dimension allowance to fit on top or at the front, regardless how you choose to use the cooler's included fans. Though, if I may suggest, you'd be better off using a pair of identical fans on the radiator, whether they're the ones that come with the x62 or another brand.
If your case supports 140 mm fans in the front, it will support the X62, look into your manual if you're not sure, if it wont, then there's no way to mount the X62 in the front.
Thanks. I do plan to use both the nzxt fans on the radiator but i wanted to mount the radiator in the bottom two front fan slots and the 140mm case fan above the radiator in the top fan slot.
