CPU Cooler Causing issues?
the one random guy
Commendable
Jul 23, 2016
25
I just installed a new cpu cooler, from the stock to the arctic freezer 13 co, the first day i put in the wrong way so idled at 50 degrees and on load got about 80, and for some reason keptn getting frame rate issues in battlefield 1 that i didn't get before, i used to hold a stable 60 at medium with the stock cooler, today i turned it around, and am getting cooler temps, but still a weird fps in games, anyone know why?
If the temps are OK, the cooler is doing its job. The cooler is not more than a fan and a piece of metal that cools down your CPU. If the CPU temp is OK, then there's no more. Therefore, that's not the cause for your fps troubles. Or at least it shouldn't.
Look for other task your CPU is doing while gaming. Maybe they are consuming more resources than you know.
the one random guy,
it's hush, hush, hush.. right now
Electronic Arts are currently shifting a lot of their servers to support Madden NFL 17 for the start of the NFL season + FIFA 17.
Right now... Battlefield 1 is taking a back seat to server support.. keep in mind that it's only BETA, so there will be a lot of issues. So, it might not be related to your hardware
