tuksonrider
I appreciate the HSF review. Thanks.
I don't understand why people want the testing in a case though. Install the same HSF into 2 different cases with different air-flow and cable management, and you'll get 2 different readings... from the SAME hsf.
There has to be a baseline. All the HSF's have to be tested the same or the data is bunk. The variable is the hsf, the constant should be Ambient temp, TIM, and setup of system to give a baseline on performance, not temperature.
It seems as people want THEIR case setup tested with these coolers.
Read the data, measure them against the baseline, compare them with each other, and decide for yourself. The final temperature is just a number against that baseline. It doesn;t matter if the temperature is measured in C degrees, apples, gold stars, whatever. It's an arbitrary number because you may not get that same number in your setup. As long as the data is compared to to against each other using a standard basline. The number they are using is just that, a number. Hell, you don;t even have to use a program that detects the temperature as correct. As long as it's the same program, and the temperature offset is the same through out all the tests.
If you look at your case setup, that should determine whether or not the top performing cooler will work for you. Your setup is subjective, the raw data shouldn't be.
Most people will just look at the pictures of the article and say, wow.. this cooler got 60C under load, I should get the same. Wrong. You should be reading the data like, this cooler performed x-amount better than that cooler in the same particular setup. This gives me a baseline on how it would perform in general. Then look at your case setup and see if it's ideal.
Yes, some of these coolers will benefit from certain air-flows configurations, but to constantly CHANGE the testing parameters to INFLUENCE the data is not testing anything at all. It's basically becomes a "how-to" guide to install a particular HSF.
Also, there should be no after-market modding like lapping. That's ridiculous. You buy a product, you expect it to perform as intended. If the base is uneven, changing that base has just scewed the data horribly because you just brought in an outside factor to CHANGE the outcome.
