CPU cooler compatible with hummer zx
May 21, 2018
6
Hi, i gonna buy a cooler for muy setup and i want to know which could be a good option.
My setup is the next:
Case: Nox hummer zx
MB: MSI B250M MORTAR (ASUS Z370F IN THE FUTURE)
CPU: I5-7500 (I7-8700K IN THE FUTURE)
RAM: 2x8GB Kingston Fury 2133mhz cl14
GPU: EVGA 1080TI FTW3
I have thinked Noctua d15 would be the best, but it's too big. What do u think about d14, be quiet dark rock 3/4...?
Thanks a lot
This is HyperX Beast which is longer than your RAMs. So it should fit. You could also increase the fan height slightly if needed which you wouldn't need.
Thanks a lot. Just for ask, i´m trying to repair windows 10 boot to fix integrated graphics driver. But when i start the usb install, the main windows of install/repair doesn´t appear. Any suggestion?
I don't understand the question, just reinstall the driver or use system restore.
As for the USB, keep hitting F8 while the system is turning on, should bring up the boot menu.
Or use the BIOS to boot directly. If both don't work, format and create the bootable USB again.
Also, this belongs in a different thread.
