Hello,
I want to change my MB. The CPU cooler I have at this moment has the backplate glued to the MB using a double-sided tape. Is there a place where I can buy that tape? It will probably rip to pieces when I'll take the backplate off. If I go to a hardware store to buy the tape, what characteristics should I look for? I guess it has to be heat-resistant.
Thanks
Thanks
