[SOLVED] CPU cooler fan points towards back of case
Axl Rose
41
5
535
Hi, I've never put a PC together so a few years ago I had a computer shop swap out the guts of my CyberPowerPC and put it into a Fractal Mini C case. I found out today that there are 2 main ways to to point the CPU fan; towards the front or facing down towards the graphics card. The shop installed my Cryorig H7 pointing toward the back of the case. Is this an issue?
Also, I can hear a noticeable difference in how loud the H7 fans are compared to the case fans that came with the case. Could I substitute the H7 fan for something else and if so what are some good ones?
Reactions: zahid0406
CPU cooler fan should "Go with the flow" and that's usually from front to back. It's less important where it's placed than which way it blows air. Fans can be...
CPU cooler fan should "Go with the flow" and that's usually from front to back. It's less important where it's placed than which way it blows air. Fans can be placed so they blow at or suck air thru cooler body.
So from my understanding, it's fine that the CPU fan is blowing air into the rear of the case and not towards the RAM?
The Cryorig H7 page says that it uses a 120x26mm square fan. Most high static pressure fans are 120x25.
Will the slight discrepancy matter?
Also, the H7 comes with the QF120 Balance fan. The QF120 comes in 3 varieties: Silent, Balance, Performance. Could I swap out the Balance for a Silent and still not have to worry about a hotter computer?
