Not sure if this is the correct place. I'm building a custom case and I'm wondering if there would be any concerns with the following situation: I'd like to remove the CPU cooler's fan and position it 1 to 2 inches above the heatsink fins. The fan would be upgraded from it's stock 120mm to a 140 or 200mm fan which I would like to provide cooling for the CPU as well as the rest of the small system it's installed in. Regardless of the exact sizes and distances here, is there any problem with having my CPU fan pull double duty like this?
Thanks!
Thanks!
