CPU cooler fan speed for high end gaming
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hey all i have a thermaltake frio ock cpu cooler and it works fine, i was just wondering i have the fan speed set to the lowest speed will it be too low to run say bioshock infinite or guild wars 2 or even crysis 3 on ultra settings, i just like it because its quieter at lower speeds, but im not sure if the lowest setting will be able to handle the heat off the cpu, so what should the ideal speed be for high end gaming (not overclocking).
Thanks
the cpu fan has a small fan controller knob that manually changes the speed, i have it currently set at the lowest setting i just want to know if running it at its lowest speed is dangerous for the heat dispersion
