CPU Cooler for Antec 300 Case w/ overclock 920?
swtrader
59
Just finished builting my i7 920 in an Antec 300 case. Right now it has the stock intel cooler and running 2.66GHz. Next step is to buy a cooler and overclock it, hopefully somewhere around 4 GHz.
Looks for a CPU cooler that will fit in the case and is quiet. Want something that will not over croud everything in the case, I've seem people have to cut out the fans/ribs of the cooler to allow space for the memory, don't want it anywhere near that tight. Also don't want a lot of noice. I'm okay with air cooled also looked at the Corsair H50, looks clean and small.
Input is appreciated.
Thanks
h50 will suck at 4 ghz there are 5 coolers i seen who will easily run an i7 at 4 ghz
prolimatech magahlm/megashadow
thermalright 1366 extreme/venomousX
noctua ud14
or go full liquid cooling the h50 is ok for a mild clock but the new coolit systems are better
swtrader
59
I know the prolimatech magahlm will not fit in the case, not sure about the others. I've also seem so many heatsinks that you have to cut the fins off the cooler to get it to fit or not enought space for the fans, etc. Looking for something that will not crowd the unit too much, quiet and supply enough cooling.
Thanks again
swtrader
59
How about the ZALMAN 9700, looks like it will fit any feed back on cooling a i7 920 at 4 GHz? Or will the Corsair H50 do as well?
galta
283
7
Zalman is not good. I had one and the results were bad. Noisy and no that effective.
Now I have a H50. If you want extra performance, get two fans instead of one (push/pull). More noise, though.
lothdk
881
69
The Zalman 9700 is not a good match for an oveclocked i7 920, especially not the overclock you are hoping for.
I have a Thermalright 120 eXtreme in an Antec 300, and I think the new Thermalright Venemous X is just a tad smaller, so that would probably be the ideal one for you.
However I am not so sure about hitting 4 GHz while at the same time running quiet.
swtrader
59
Is there a specific model of Coolit you recommend? They make several version.
CoolIT Domino A.L.C.
CoolIT ECO A.L.C.
CoolIT Vantage A.L.C.
Thanks again
swtrader
59
Anyone have an Antec 300 w/ an OC i7 920 that can recommend a cool? Starting to lower my requirements of 4 GHz since none of the good coolers seem to fit in the Antec 300 case.
Thanks
Similar threads
