CPU Cooler for Cooler Master K350 Mid Tower Case
kadonomi
Specs:
CM K350 Mid Tower Case
MSI FM2 A75MA-P33
AMD A8 5600K
Looking at the reviews, I'd have gotten the Hyper 212 Evo/212x if only they'd fit the case, which I think they don't. I am currently considering the Thermalright True Spirit 120M but I'd like to hear your opinions on this matter.
If you don't have a budget in mind, in my opinion the best cooler you could buy that is low profile would be the Noctua NH-C14
http://www.newegg.com/Product/Product.aspx?gclid=CPup8Pf_gb8CFSlgMgodezUAhg&Item=N82E16835608020&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-CPU+Fans+%26+Heatsinks-_-N82E16835608020&ef_id=U54uSAAABEtkk6kK:20140617225219:s
If it is too tall, you can remove the top fan and it will fit.
If you want to use the Thermalright True Spirit and it fits, it should give you decent temperatures, especially if you replace the fan.
I am in the same situation as you! Just wanted to ask for an update with what CPU fan you bought as I am deciding between the Noctua NH-L12 or the Noctua NH-U9S.
Thanks,
Costa
