Cpu cooler for fx 8300
Benkimon
31
Good aftermarket cooler for FX 8300,
Cryorig H7 or Arctic Cooling Freezer 7 Pro rev.2 and how much watts is needed for it?
And if possible can someone recommend a good cheap case that has a psu mounted at the bottom?
Thanks in advance!
Ps does the cooler fit on asus m5a78l-m lx3?
The contact 12 is available from hgshop
https://www.hgshop.hr/hladnjak-za-procesor-thermaltake-contac-16/proizvod/219454
Cases - all budget with decent preinstalled cooling fans - cheapest to most expensive, all bottom mount psu's
Zalman z1 - 2 fans
https://www.hgshop.hr/proizvod/kuciste-zalman-z1-bez-napajanja/191814
Zalman z1 neo - 3 fans
https://www.hgshop.hr/proizvod/kuciste-zalman-z1-neo-bez-napajanja/209349
Zalman z3 plus - 4 fans & 3 speed fan controller
https://www.hgshop.hr/proizvod/kuciste-zalman-z3-plus-bez-napajanja/191813
Zalman r1 - 3 fans + fan controller
https://www.hgshop.hr/proizvod/kuciste-zalman-r1-bez-napajanja/198625
Favourites out of those for me are the z1 neo & r1
I would recommend Antec GX500 case and Scythe Mugen 4 cooler. It might be a bit tricky to install the cooler but I own it and it keeps my FX-6300 under 55 celsius while ambient temperature is 30. My CPU is overclocked to 4.2 GHz btw.
Im from Croatia. (Its only 38°C )
A cheap case would be something below 40e
If i want to buy a cooler i would need to move my PSU down. Im really scared to put a cooler below a PSU. I dont want it to draw hot air
so u think there is no need to buy a new case, just a new cooler?
My present case has only 2 spots to put vents, kind off its bothering me
PS do u think Cryorig H7 is compatible with my MBU? I saw some reviews, everyone says that that is one of the best cheap coolers u can buy 😛
Well there is links, vecom, infokom, hgspot and more. I can order from amazon also.
The only cooler available here is arctic cooler that i already named (its from hgspot).
I guess i wont buy a new case then, just tell me, gammax or arctic or even zalman cnp5x (also from hspot)
Zalman z1 - 2 fans
Ill calculate the price in store when i get there, but mostly u are right.
Ill just take that Thermaltake and and mby Z1.
Ty very much for the effort. Have a nice day!
I've just been looking at that ms Cyclops 2 case - I knew I'd seen these before , they're branded game max in the UK ,they come with 2 fans over here.
Its a nice case , check to see if it comes with fans (if you're going to an actual physical store) , I don't think it does over there though.
I would say if you can do that case & a couple of decent 120mm fans for the same or less than the z1 then its probably actually a better case - not as good as the z1 neo though.
