CPU Cooler for H110M-DS/ Hyper MoBo
jessemosely
I recently bought an Ibuypower PC on sale(open box) https://www.newegg.com/Product/Product.aspx?Item=N82E16883227734
The only issue I am running into right now is the CPU fan is far too loud. The temps aren't bad at ~30c - 35c idle and not above 52c with light gaming(Torchlight2).
(Right now I have the target tempt set at 40c so the fan isn't always at 100%)
I was thinking of either just replacing the fan on the cpu cooler or just getting a new cooler.
I have run into a bit of an issue trying to find either that looks like it will work. The existing fan seems like an odd ball at 75mm. While as far as a new cooler goes rather than a height issue it's one of depth and length. I am not sure there is more than.... VERY rough estimation would be 85x90mm.
I can't really track down info on the Asrock H110M-DS/ Hyper motherboard to try to figure anything out.
If there is anyone with experience with the board or knows a cooler that will work for an AM3+ socket (FX 6300). Or just a way to switch out the fan(4pin). Input would be appreciated.
thx
Those factory fans are noisy by nature and no fans of that size are actually quiet. What you need is an aftermarket cooler with at least 120mm fan and 3 heat pipes.
Something like this: http://www.lc-power.com/en/product/power-supplies/lc-cc-120/ which could cool processor even at minimum fan RPM.
Latest posts
