P prathampant25 Prominent Oct 24, 2017 17 0 510 Oct 26, 2017 #1 Is noctua nh d14 enough to overclock i5 8600k to 5 ghz
Solution Isokolon Oct 26, 2017 Depends on the AIO and your case. Usually the ND14 can at least keep up with them.
P prathampant25 Prominent Oct 24, 2017 17 0 510 Oct 26, 2017 #2 Also is it worth to buy i5 8600k instead of i7 8700.i can wait till the release of b360 Mobo. I will only do gaming Thanks Upvote 0 Downvote
Isokolon Judicious Jul 24, 2016 6,369 108 34,390 Oct 26, 2017 #3 If you want to OC the CPU you have to use a Z370 board. Also not all i-8000 CPUs can reach 5GHz. The NH d14 is one of the better coolers out there Upvote 0 Downvote
P prathampant25 Prominent Oct 24, 2017 17 0 510 Oct 26, 2017 #4 Isokolon : If you want to OC the CPU you have to use a Z370 board. Also not all i-8000 CPUs can reach 5GHz. The NH d14 is one of the better coolers out there Upvote 0 Downvote
P prathampant25 Prominent Oct 24, 2017 17 0 510 Oct 26, 2017 #5 I know about silicon lottery and also about overclock enabled z series Mobo . I want to know can noctua nh d14 gave same performance like a 240mm aio cooler Upvote 0 Downvote
Isokolon Judicious Jul 24, 2016 6,369 108 34,390 Oct 26, 2017 Solution #6 Depends on the AIO and your case. Usually the ND14 can at least keep up with them. Upvote 0 Downvote Solution
J johnny1121 Prominent Nov 21, 2017 8 0 510 Nov 21, 2017 #7 The be quiet dark pro 3 is a solid cooler too, maybe not quite as good on temps as the noctua but definitely better looking if you care about that =D Upvote 0 Downvote
