I was wondering which CPU cooler would be best for my mini-itx build. I have this case:
Lian Li PC-Q17
I only have around 50mm of clearance between the motherboard and the top of my case. I have a 1080 that will barely fit in the case, so the airflow from the bottom will be quite limited. Because of that, I was considering a 120mm liquid cooler. For aesthetic purposes, I'm trying to avoid mounting a radiator on the top of my case and am trying to keep all cooling solutions contained within the case.
I previously bought a Corsair h90, as the case supports a 140mm radiator, however, the cooler and fan was a bit too big to fit in the case. I haven't been able to find any 140mm low profile fans with decent static pressure that have 140mm mounting options.
Due to the abundance of (at least compared to the 140mm fans) of 120mm low profile fans with high static pressure, I was considering the Corsair h55 or h60. I'm wondering if another liquid cooler or a decent air cooler would be better than either of these. My CPU is a 6700k, and I will probably do a slight overclock, nothing that requires voltage adjustment, as I realize my cooling won't be great. Any suggestions are appreciated.
Lian Li PC-Q17
