CPU cooler for sharkoon tg-5
twantenho
16
I am going to build a new pc and I am asking myself if I need a cpu cooler for the sharkoon tg-5. The tg-5 actually has a led fan on the back of the case where the cpu is. I have i7-7700 and I am not going to use it for overclocking, so is a cpu cooler then needed?
Already thank you
the 7700 should come with a cooler as long as it is not a K-Variant....
I'd also look for a case intake fan or two up front if your case supports it....
You can check HWMonitor after it is built, monitoring temps during it's use to see if you are comfortable with it's CPU temps...; givena stock cooler, I'dexpect idle to be roughly 40C, and medium gaming load temps about 70-75C
What whould be a acceptable temps for a cpu while gaming. I forgot to say that the case also has 3 led-fans on the front of the case, so I guess that that will also help with lowering the temp
