CPU cooler for small case - i7-4820K
Rudy93
11
Hello I want to upgrade my CPU cooler because I have standard Intel Socked LGA2011 cooler and it's really loud when I'm playing games. One of the problems is that I have small case. Second one is when I wanted to upgrade it through the website where I bought the computer, it said that the Corsair H60 will not fit in my case. This is the case:
https://www.pcspecialist.co.uk/case-images/1866/
And my motherboard is ASUS P9X79 LE. My budget for new cooling fan is up to £75.
Well, the H80i mounts to a 120mm fan mount on your case. I imagine the pcspecialist site does not say it will fit because the case has no *additional* spots to mount it aside from the rear 120mm exhaust. Simply remove the stock rear exhaust fan and install the H80i right there, I don't see why it would be a problem.
