K kbone30 Prominent Feb 20, 2017 1 0 510 Feb 20, 2017 #1 My CPU cooler (Hyper 212) currently covers my first ram slot, but i need it open due to a soon upgrade. Is there a way i can flip my CPU cooler and then put the fan on backwards to have the same effect?
Solution Dark Lord of Tech Feb 20, 2017 Put it on the other side in a pull configuration it will only be a few degrees difference in cooling.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,867 1,895 159,590 Feb 20, 2017 Solution #2 Put it on the other side in a pull configuration it will only be a few degrees difference in cooling. Upvote 1 Downvote Solution
