CPU cooler help
culzone
555
Corsair H75 or EVGA CLC 120? I only have 29mm depth space.
or any other liquid cooler you know about?
I've got the silverstone rvz02 case and im using a 172mm gpu
No way you can do liquid cooling in that case unless it is a custom loop and most of the hardware is on the outside of the case. This would be the closest to what would work but even this would not fit unless you kept the side of the case open. http://www.corsair.com/en-us/hydro-series-h5-sf-low-profile-liquid-cpu-cooler
This is more along the line of what you would need. https://www.newegg.com/Product/Product.aspx?Item=9SIA4UF39D5213
Total size 47mm
The limit of the cpu cooler height is 58mm. That is what it says on the case page on the product website.
I have some space next to the gpu and i've measured it carefully and a H60 can fit :) so I think im gonna go for that
