CPU Cooler Help
Jul 14, 2018
So I'm looking for a cpu cooler for under 30 bucks that can fit inside the corsair 100r (150mm). I've gone through the cryorig h7, the cryorig c7, and the bequiet pure rock slim, because I keep reading that there are some installation issues for motherboards already mounted on the case. So if I could get some suggestions, that would be great. Thanks
PC Specs
Intel core i7-7700k LGA1151
ASUS H110M-A Motherboard
G. Skill Ripjaws V low profile 8GB
Corsair 100R Case
Jul 14, 2018
Ok thanks but someone also said that the h7 is hard to install on to Asus mini itx boards because the backplate interferes with the installation process, would that be a huge problem?
