CPU cooler installation
gooddayz
32
Hi,
I am buying a Cooler Master Hyper T4 CPU cooler for a Gigabyte 970A-D3P, Using the CPU FX 8320. I was wondering am I able to just use the clips (No backplate) on the cooler in the already placed plastic mounts on the motherboard?
Thanks
that's for intel though, with the AM3+ Socket it has already plastic mounts that can support the cooler without backplate (Clips), just wondering if that is doable or not.
