Cpu cooler no higher than 134mm
j0ndafr3ak
409
Hi,
Can you advise a good cpu cooler no higher than 134mm? I would like to get a Bitfenix Pandora Window and that's the max height allowed for heatsinks. it's for a fm2+ build. thanks
Youre looking at a lp blower mate really ,99% of even the 92mm towers are 135mm or do.
The zalman cnps5x 'might' fit & its a decent little cooler for the money but not spectacular.
I will recommend the raijintek Pallas ,I use one myself ,& its a pretty spectacular performing 140mm flat blower - you may not like the looks ??
But it honestly does a great job & is near silent.
http://www.raijintek.com/en/products_detail.php?ProductID=9
^ Pallas wasn't around then though mate - the only one that is even close performance wise is the noctua with both fans fitted which costs twice as much & is damn ugly.
I used to own the big shuriken 2 - decent cooler but the pallas absolutely batters it .
Were talking 10c off the CPU temps & 20c+ off the vrm temps while being a lot quieter.
