Cpu cooler not working properly.
intelfanb0y
72
Hello
I just built my new system and everything works fine except cpu cooler (NZXT kraken x41) i plugged the pump into cpu_fan and the actual fan into cpu_opt when i turn it on the fan is working but the pump isnt so i connected the pump into a chassis fan 3 pin and it was working fine along with the fan but my motherboard wouldnt let me go to windows because there was no cpu fan detected in the cpu_fan connection. Any advice?
Cooler:NZXT kraken x41
Motherboard: Asus rampage V extreme
Thank you in advance
I did connect the usb cable and the pump to the cpu fan header but when i connect the fan to the vonnector but it didnt work
the problem is that my motherboard shows the fan as spinning but the cpu fan which is the pump shows as if it wasnt connected
I changed it and it didn't work but pump connected to chassis fan header and fan connected to cpu opt it shows error i go to bios press discard and exit and takes me to windows weird but now it works
last question is there a way to avoid displaying error by tricking motherboard?
