CPU Cooler Options
PAULeD16
hello just had a few questions about a build im putting together. What type of cpu cooler can I use in this build, the case says the cpu cooler can be a maximum of 150mm ? What would be the best way to have wifi and blue-tooth on this build?
here are the specs:
Intel 3.70 GHz Core i3-6100 3M Cache Processor
Gigabyte Micro ATX 2 x DDR4 DIMM 4 x SATA 6Gb/s Motherboard (GA-H110M-H)
Corsair Carbide Series 100R Mid Tower Case
Ballistix Sport LT 8GB Single DDR4 2400 MT/s (PC4-19200) DIMM 288-Pin
WD Blue 1TB SATA 6 Gb/s 7200 RPM 64MB Cache 3.5 Inch
EVGA GeForce GTX 1060 3GB GAMING, ACX 2.0 (Single Fan)
EVGA 500 W1, 80+ WHITE 500W
Thank you very much for the reply and suggestion! P.S. i forgot that you could get usb bluetooth sorry!
