Cpu cooler or fans
jazgreen99
95
Hi all I would like to find out if a cpu cooler is necessary?
I have a p400s case and I’ve added another 2 140mm fans to the case
Nobody said anything to me about a cpu cooler only extra fans
My specs are
Ryzen 3 2200g
Xfx Radeon 570
8gb ram
Super Flower 750W 80 Plus Platinum
Asus b450 prime plus MB
P400s case
500GB SSD
3 extra 2.5 1tb hard drives
My case is Silverstone TJ-08E.
It has a single front 180mm intake fan that is filtered and running on the low speed setting.
My only other case fan is a 120mm exhaust.
Inside is a GTX1080ti and a I7-8600K running at 5.0.
The cooler is a noctua NH-D15s.
I have no temperatures issues at all.
Ah great thank you. So is it ok that I’ve added another 2 140mm fans to my case?Do more fans make a difference if you would have to compare to adding a non stock cpu cooler. I thought I’m wasting money on extra fans when maybe a cpu cooler would be better
A cpu cooler is always required.
But, the cooler that comes with your processor is entirely adequate.
Any cooler, and that includes the graphics card cooler needs an adequate supply of fresh air to do it's job.
The RX 570 is a relatively not graphics card.
You did, I think, a good thing by ordering two 140mm fans.
Install them in the front of the case as intakes.
140mm fans move more air at lower rpm and will be quieter.
Since all the air intake is in one place and filtered, your parts will stay cleaner.
Keep one 120mm fan for rear exhaust. Mostly to direct the airflow to the rear.
I might not even use the other.
Too much exhaust will tend to draw in unfiltered air from adjacent openings.
@geofelt thats exactly what i was thinking 2x Fractal Design FD-FAN-SSR3-140-WT Silent Series R3 140mm Low-Noise Case
Fan in the front and 120mm at the back as the exhaust.the reason i asked about a cpu cooler is i see builds on youtube and everyone takes there stock fans out literally.how many fan slots are there in the p400 case?how many should i have and do i need more.rather safe than sorry lol
Front: 3 x 120mm or 2 x 140mm fan (1 x 120mm fan included)
Top: 2 x 120mm/140mm fan
Rear: 1 x 120mm fan (included)
Two 120/140 as intakes in front and one for exhaust will be sufficient.
I like 140mm fans because they push more air at lower rpm and are quiet.
I like the noctua fans for quietness.
Consider the size and number of fans on your cpu cooler and on your graphics card.
That is what you are trying to feed with your case intakes.
More fans and higher rpm fans will push more air but at a cost and more noise.
If ever you think you need more, (which I doubt) you can always change some out.
My optimum suggestion is to use 2 140mm front intakes and just one rear exhaust.
Whatever air comes in the front will exit somewhere, taking component heat with it.
If the front intake is filtered, your parts will stay cleaner.
Adding top fans either as intake or exhaust will draw in unfiltered air and you will need to clean your parts regularly.
